5-26-2021
Discussion in 'Changelog' started by robregen, May 26, 2021.
    * Clients will now send all position updates to nearby clients. Removed client update packet filtering.
    * Fixed an issue with bash/kick skills not interrupting spells when the bash/kick does not cause a stun.
    * remove logic that incorrectly added spell haste to high level NPCs (credit to mackal)
    * exclude bards from requiring spell reagents
    * reset intoxication and air in lungs on death
    * fix a bind wound related crash
    * zero npc movement deltas when pathing - temp fix for jerky mob movement
    * sebilis: Granite Face Grinder added to loot tables.
    * sebilis: 'spectral duke' NPCs will now spawn.
    * fix timer and target type for Spirit of the Wood AA
    * Exotic Drinks (Stein of Moggok): adjust the faction requirement for final turn in.
    * Jaled Dar's Shade: fixed a spelling typo.
    Mechaike, Manstache, Sketchy and 8 others like this.
  2. sowislifesowislove
    Very cool. So the stinability of a mob, I.e. 55+!doesn’t matter anymore? And there is potential to interrupt like a 55 Templar in ssra now can be interrupted?
    Manstache likes this.
  3. solar
    They should start taking 10 sec to CH now too instead of 5 sec, so healer mobs got it rough after this patch.
    Mechaike, Manstache, Mokli and 3 others like this.
  4. Haynar
    Mobs 55+ were not running thru the interrupt code correctly. The interrupt chance goes down as mob level increases. Level 62+ mobs are like 2% chance to get interrupted by a bash.
    Unstunnable mobs, like giants, still cannot be interrupted by bash. But cleric snakes in ssra? Back on the menu.
    sirhc, Mechaike, Manstache and 6 others like this.
  5. Radda
    Radda People Like Me
    :D
  6. Mokli
    Is this relative to your own level? Meaning in PoP a lvl 62 mob will be easier to interrupt than now.
  7. Haynar
    Not totally relative. Caps are based on mob level. So mob level 62. If you were level 100. Its 2%. The chance to interrupt is based on level difference.
