5-25-2022
Discussion in 'Changelog' started by robregen, May 25, 2022.
    * Added a routine to allow 'streetsweeper' NPCs to function.
    * Feigned Minion AA fixed.
    * Poison Mastery AA fixed.
    * Apply Poison now works a little more accurately.
    * Spell Disjunction of Flame made dispellable.
    * Harm Touch AA timers adjusted. The 2 AA buttons should work better and benefit from timer reduction AA.
    * Apply damage shield effects before melee damage (makes druid AA Wrath of the Wild work better)
    * Some swarm pets had their stats adjusted.
    * Mithaniel's Binding AA healing was reduced.
    * Nightmare Silk String should now be unstackable.
    * Set Rule to not idle in all zones.
    * Added a bunch of missing dialogue across Vanilla zones
    * Added Cure quest to Brother Nallin in NK
    * Added Azrax's Legacy quest
    * Updated/Tested most the quests on this thread that weren't already marked off
    * Tovax / Scruffy should now path like live according to the Time zone. Tovax - night, Scruffy - day
    * Tovax should now drop the note near Surefall when he paths up north.
    * rivervale: Improved the Nillipuss and Reebo scripts a bit.
    Lyrina, Mechaike, Ravenwing and 3 others like this.
  2. Cadsuane
    "Feigned Minion AA fixed."
    What was broken with it, and what changed? I never used it on AK, so wasn't sure about expected behavior. (Mostly used it to drop agro and suspend a pet before it would die to AEs here)
  3. Torven
    It wasn't turning off attack so the pet would just re-attack immediately after use. It wasn't emoting on fail. It had no timer so it could be spammed.
  4. Mokli
    "* Added a routine to allow 'streetsweeper' NPCs to function."
    What's a streetsweeper NPC?
  5. Cadsuane
    detailed Discussion in discord general channel stayed at 920 am CST.
    NPCs who pick up items you drop.
  6. Elroz
    in vanilla zones, there were npcs that would pick up items if they walked past them. They usually do some kind of emote. I think the most commonly seen example would be nillipuss when he picks up jumjum off the ground:
    Nillipuss says, 'Look what I've found! What a great find! It used to be yours, but now it is mine!'
  7. Faults
    This patch changed the damage on Staff of Transcendence from 54 to 53 - intentional?
  8. robregen
    Yeah. It was intentional. Not that big of a change really.
  9. Mokli
  10. Mokli
    *not
  11. Zentile
    Zentile Member
    For a L65, 305 Str, 175 Worn ATK, 325 Spell ATK, 100% Haste, 25% Overhaste Monk vs. Aten this drops overall dps by ~3. Dual wield is now higher depending on weapon combos and mob resists, with Shinai of the Ancients/Hammer of Time Weaver now ~4 dps higher than the nerfed Staff of Transcendence.
    Zentile
  12. robregen
    okay I see you made your point. I'll "unnerf' the "nerf" Staff of Transcendence.
    Ravenwing and Elroz like this.
  13. Elroz
    as someone who used staff of transcendence and shinai/timeweaver on live, 1h on raids, 2h everywhere else was my setup.
  14. Ravenwing
    It's a small change either way, but I think this is a good call: looking at the history, this item was first added to Lucy in mid-July 2003 and bumped up to 54 damage at the beginning of August. So while I imagine 53 damage is technically AKurate, in reality, on Live, the 53-damage version of the stave existed for two or three weeks and probably only in one or two people's inventories.
  15. robregen
    I searched through the log and it came up with this:
    my apologies.
    Elroz and Ravenwing like this.
  16. Elroz
    did it happen to mention the proc damage? i think it's doing 150 dmg on takp, but I remember 200dmg on proc
  17. solar
  18. Mokli
    2003-08-06 10:17 Changed Resistadj from -150 to -200
    2003-08-06 10:17 Changed Slot 2 from "Stun(3.00 sec/65)" to "Stun(3.00 sec/68)"
    2003-08-06 10:17 Changed Slot 1 from "Decrease Hitpoints by 150" to "Decrease Hitpoints by 200"
    2003-04-08 11:05 Initial Entry
  19. Zentile
    Zentile Member
    Was this intentional on the Mace of the Ancient?
    Before Patch: L60, max hit 97s, triple attacks, four attack rounds + two special rounds (bash or kick) before despawning, looks like a skeleton holding seru's sword
    Since Patch: L40, max hit 94s, double attacks, six attack rounds + two special rounds (bash or kick) before despawning, looks like a skeleton holding seru's sword
    The Mace of the Ancient pet is now identical to the PoE monk swarm pet except for appearance and the possibility to bash instead of kick.
    Zentile
  20. Zentile
    Zentile Member
    Sorry, should have added this too...
    Mace of the Ancient
    Before Patch: hits for 48-97, ~480 dmg per proc on exp mobs, ~350 dmg per proc on raid mobs
    Since Patch: hits for 12-94, ~380 dmg per proc on exp mobs, ~230 dmg per proc on raid mobs
    So overall dps from the pet has dropped significantly.
    Zentile
    Radda likes this.
  21. Torven
    Yes that was intentional
    Radda likes this.
