Code: Haynar * Fixed issues that caused zoning to the safe points by mistake. * Added another fix for mobs being stuck below the world in roamboxes. * Added compiler options to improve code performance. Torven * NPCs were previously not casting spells set to use the snare AI logic if they were in melee range of their target and they now do so. * NPC casters now more likely to cast different nuke spells in their spell lists. * NPCs will now equip non-weapon off-hands (e.g. instruments, glowing black stone, stat books) * Root tick saving throws on low MR targets are now less likely to succeed. * Roots will now break more easily when casting direct damage spells against rooted targets that are not around the same level as the caster. Database: Torven * Aggro radii adjusted (mostly reduced, but some raised) for NPCs in the following zones: innothule, guktop, feerrot, sro, oasis, nro, commons, ecommons, befallen, nektulos, kithicor, highpass, cauldron, tox * templeveeshan: Assist radii of raid boss NPCs reduced. * innothule: Added faction warring to some NPCs. * innothule: Lynuga respawn time reduced significantly from last patch, but still much higher than what it was before last patch. * innothule: Sir Edwin Motte removed from zone. * feerrott: a_skeleton added to the zone. * feerrott & innothule: Respawn timers adjusted for some spawns. * feerrott & innothule: Missing NPC emotes added to several NPCs. * kithicor: added faction war with bixies and goblins. Robregen * NPC Enchanter Spellset: remove rapture spell. * NPC Ranger Spellset: remove swarm of pain. * Veeshan's Peak: removed level requirement since AK had none. Script Torven * necropolis: Jaled Dar`s Shade depop timer removed. * innothule: The Ivandyr's Hoop reward made less common. * freporte: Added more dialogue to tavern NPCs and scripted the bar fights. Robregen * fearplane: Golem's death should no longer spawn a doug with a 70's wig model.
you should probably specify that this was removed from NPCs spellsets you confused some guildmates thinking it was removed from players spell books
Oh man, I really wish I had gone back for that -10svm book I used to use when charming. Now it might actually lower resists I take it?
You aren't. It isn't flagged as a weapon here. Which is a bummer. Can use as a pet weapon on p99. Not sure about Live. Guess I could hop on to see.
Sure, but I don't travel to the Bazaar. Can you meet me in PoK? You would have to log in to the game first though.
Something I started noticing is that with the last patch, "the long zone times when zoning multiple characters at the same time" bug may have returned. It did for me at least.
