Code: Cavedude * Fixed a memory leak in SendWearChange(). * Zone will now only load emotes that are used by NPCs in the zone. * Fixed the issue causing NPCs to attempt to cast the same spell family over and over. * Items dropped to the ground will now always point north. Haynar * Fixed memory leaks associated with sending merchant inventory to clients. * Fixed memory leaks with combining fragmented packets from the client. * Added some optimizations to packet allocation in a few processes, and fixed some inconsistencies. * Fixed potential memory leaks with creating spawn/despawn packets. * Moved queue'd clientlist to std::deque. Speedz * Removed unused files and code. * Moved a versioning system to world out of common, as it is not a "common" function. Script Robregen * Correct the text reward on Sentry Kale "Dragon Tooth Choker" quest. * added a missing reward text and faction for Thekela_Meepup Misc Haynar * Updated poknowledge.path to lower cpu use version.
