Code: Haynar * Added a way for scripts to search cursor queue for an item. Solar * remove a duplicate spell message * fix group member health bar not showing correct value when new member joins raid group Robregen * Fix GetSafePoints to check and deal will nullptr being sent as short_name Database: Robregen * Gauntlets of Disruption: worn effect should now display on the item info window in-game. * Cape of Endless Torment: Correct Flowing Thought to be 6 instead of 4. * Flameless Lantern: should no longer display any charges. * Craft muffins now uses a different item that are unique to muffins sold from merchants. * Qeynos Catacomb: added pathing and missing NPCs in the lower level (smuggler area) Torven * potimeb: The appropriate Saryrn adds are now flagged unmezable. * potimeb: The 60th player to zone in should no longer be refused entry. Script: Robregen * Added new quests: Fresh Baked Muffin, Trumpy's Head, and Trumpy's Skull. * Added additional rewards for Bloody Shank and Illegible scrolls. * Added missing text for illegible scrolls. * Change the faction requirement for Tattered Pouch quest. * Fixed the turn in dialog for Werewolf Hunters. Haynar * Added a method for Client::HasItem to search the cursor queue
Minor clarification: was it just the 60th person being bounced due to the zone limit, and now that its' fixed the server will allow 72 to be raid-shuffled into TimeB as on AK, limited by the periodic script check?
Code had been reverted to the previous state. There was a major overhaul in the code I did with splitting files and renaming variables. Too much changes all at once wasn't a good idea.
