Code: Cavedude * Dying while LD will now correctly send you to your bind point. * Spirit of Bih`Li will again properly stack with illusions that aren't also runspeed buffs. * Throwing and ammo items will no longer be placed in a container that is below their size capacity when a trade is canceled. * Added wandertype 8, which is labeled GridRandomCenterPoint. Wandertype 7 has been renamed to GridCenterPoint to avoid confusion. This new type causes a NPC to alternate between a random waypoint in grid_entries and a random waypoint marked with the new centerpoint column set to true. If no waypoints are marked as a centerpoint, this wandertype will not work. There is no numbering requirement or limit for centerpoints. You can have as many as you need. Haynar * Updated damage message range. Robregen * Config File Update Initial Update (phredi from eqemu) * Fixed various compile errors due to Config File update commits(KimLS, Mackal, Akkadius from eqemu) * Add luaRock Support (Mackal from eqemu) * Allow admin telnet connections from localhost without requiring credentials to world (Akkadius) * fixed various memleaks (Mackal from eqemu) Database: Torven * mischiefplane: Some missing spells/procs added to NPCs and some stat adjustments. Script Robregen * fixed a couple of name that should reflect a player's name with Atheling Plague and Hierophant Dexl.
