Code: Robregen * Pickpocket now works to a max of 5 levels below you, or level 45...whichever is greater... You can pickpocket NPC up to level 55 if you are level 60. source: https://everquest.allakhazam.com/history/patches-2001-1.html and https://thesafehouse.org/forums/for...1-searched-nothing-useful-came-up-pick-pocket * Only humanoid type NPC can be pick pocket. Haynar * Updated exp rate check. * Mobs snared to a stop should adjust their heading now when fleeing. Database: Robregen * Food Satchel Recipe: should now be combinable. * Fixed the stacking issue with Featherwood Bow Staff and Stonewood Bow Staff. * Most PoP zones will not idle except for nightmareb and hohonorb.
I believe NPCs should be pickable at least to level 60 (5 levels below your max level) based on that patch note. I thought it was equivalent to your level but 5 levels underneath sounds more correct because I always heard fables of pickpocketing the concillium reports for Seru Earring #3 and those mobs are mostly level 60 which would make them max level for a 65 rogue. https://everquest.allakhazam.com/db/quest.html?quest=2148&p=2#comments I believe this guy just typo'd 55 instead of 65. But more people claiming to pick pocket level 60 trash mobs from 2002: https://thesafehouse.org/forums/for...ity-1st-2nd-3rd-4th-arx-key-5th-may2003/page4
