Code: Torven * Beneficial aggro from the result of spells not castable by the class of the user (i.e. procs, clickables) is now capped at 400 hate. * Bard songs were previously adding hate twice and this was corrected. * NPC AI will now refuse to attempt to cast a Complete Heal if a previous attempt at casting this spell is less than 8 seconds ago. Haynar * Fixed an issue around zone line areas, where you cannot cast spells on your target. This fixes issue around VT zonein. * Made pathing changes, to help fix issues with mobs falling, like guards around Arch Lich in ssra. * Sacrifice now uses the same exp loss equations as death. * Added some webhooks changes. * Added some packet reduction for animations sent to clients, which get quite spammy in raid situations. Database: Torven * maiden & umbral: NPCs now regenerate a small amount of HP in combat like most NPCs. Robregen * Tradeskill: correct the Shaded Hide Recipe to use ME version of Shaded Hide Amice instead of VT. * Correct the heading on zone in from Twilight to Fungus Grove. Script: Torven * grimling: The final war event was significantly modified for accuracy. * grimling: The Husman raid event was significantly modified for accuracy. Robregen * Added a missing dialog and faction for Marv Orilis in East Freeport.
* Beneficial aggro from the result of spells not castable by the class of the user (i.e. procs, clickables) is now capped at 400 hate. Assuming this would include mallets?
In terms of Bladestopper is that 400 hate total per click depending on witness, or 400 total, even if all clicks are witnessed?
Ya I think it’s all clickes Mok, but I think the impact will be to rune spells/procs like the Bladestopper.
