Code: Haynar * Rooted mobs should attack mobs close by better. * Improved some mob pathing in water. * Pets trying chasing mobs in water should do a better job. They shouldn't go off in weird directions and get lost so much. * Mobs pathing home, or to fixed locations should navigate obstacles better. This should improve cases where mobs get stuck trying to pathing to waypoints, or back to spawn points. Torven * Fix for NPCs getting stuck in casting * Improvements to the recent wp_spawns option Database: Robregen * Dawnshroud: A Blazing Rockhopper should now emote correctly * Kithicor: Readded a missing faction to DE rogue epic NPC.
This SSRA rotation for us the perma rooted snakes Destiny have tanked, R1 & R2 will not turn and face the player with aggro. They stay staring out in the original direction, although the do appear to do damage to the player with aggro if behind the MoB but the rooted mobs rotation stays the same. I can not personally confirm if AL or other perma rooted mobs not mentioned have this same behavior. Sorry if this should be a pathing bug report
also noticed that when normal mobs are rooted (with root type spells), they don't face and turn to attack the player they do swing and hit though, just don't face the player
I've also had a couple of instances of feared mobs that continue attacking instead of running away feared. They are not rooted, but they are snared with necro darkness dot snare line. Not sure if related.
[Wed Jan 30 13:55:55 2019] You begin casting Invoke Fear. [Wed Jan 30 13:55:55 2019] You haven't recovered yet... [Wed Jan 30 13:55:55 2019] You haven't recovered yet... [Wed Jan 30 13:55:55 2019] You haven't recovered yet... [Wed Jan 30 13:55:56 2019] Taunting attacker, Master. [Wed Jan 30 13:55:56 2019] Gylton claws YOU for 49 points of damage. [Wed Jan 30 13:55:57 2019] You regain your concentration and continue your casting. [Wed Jan 30 13:55:57 2019] Gylton looks very afraid. [Wed Jan 30 13:55:57 2019] Gylton kicks YOU for 21 points of damage. [Wed Jan 30 13:55:58 2019] Gylton claws YOU for 45 points of damage. [Wed Jan 30 13:56:00 2019] Your Coldain Military Wristguard feels alive with power. [Wed Jan 30 13:56:01 2019] Gylton claws YOU for 69 points of damage. [Wed Jan 30 13:56:01 2019] Gylton claws YOU for 32 points of damage. [Wed Jan 30 14:30:56 2019] You begin casting Invoke Fear. [Wed Jan 30 14:30:56 2019] Your Coldain Military Wristguard feels alive with power. [Wed Jan 30 14:30:56 2019] You can't use that command right now... [Wed Jan 30 14:30:58 2019] Entalon claws YOU for 100 points of damage. [Wed Jan 30 14:30:59 2019] You regain your concentration and continue your casting. [Wed Jan 30 14:30:59 2019] Entalon looks very afraid. [Wed Jan 30 14:30:59 2019] Taunting attacker, Master. [Wed Jan 30 14:31:00 2019] Entalon claws YOU for 23 points of damage. [Wed Jan 30 14:31:00 2019] Entalon claws YOU for 23 points of damage. [Wed Jan 30 14:31:01 2019] Entalon bashes YOU for 20 points of damage. [Wed Jan 30 14:31:06 2019] You begin casting Invoke Fear. [Wed Jan 30 14:31:06 2019] You can't use that command right now... [Wed Jan 30 14:31:08 2019] Entalon claws YOU for 89 points of damage. [Wed Jan 30 14:31:08 2019] Your Coldain Military Wristguard feels alive with power. [Wed Jan 30 14:31:09 2019] You regain your concentration and continue your casting. [Wed Jan 30 14:31:09 2019] Entalon looks very afraid. [Wed Jan 30 14:31:09 2019] Entalon kicks YOU for 24 points of damage. [Wed Jan 30 14:31:10 2019] Entalon claws YOU for 89 points of damage.
