Stamina to hitpoint conversions
Discussion in 'General Discussion' started by Pithy, Dec 20, 2016.
  1. Pithy
    Can anyone point me to the functions in the last open TAKP source that convert stamina into hitpoints for each class? I ask because TAKP magelo and TAKP server give wildly different hitpoint numbers, and it's not clear where the bugs are. TAKP magelo is definitely buggy, and not just for sta-->hp maps, but is it possible that TAKP server's calculations are off too?
  2. Haynar
    You compared server to client?
  3. kicnlag
    kicnlag Active Member
  4. Haynar
    Does anything match the client? Or are all the numbers different?
  5. Pithy
    Thanks kicnlag, will poke around a bit.
    Haynar: how can I check whether the server and client agree? Dig through the github code and run a few sample calcs, compare to what the client displays?
    Magelo does not match the client.
  6. robregen
    usually if the client doesn't agree with the server. You'll noticed a fluctuates on your HP bar like it goes up and down. If it doesn't do that then the client agree to it.
  7. Haynar
    I thought cavedude matched client to server.
  8. robregen
    yeah he did. or so I think he did.
  9. Pithy
    Okay, thanks guys. I don't see any client-server jitter in game; hitpoints stay nice and steady (aside from tick-based regeneration). I also ran through a couple of spot calcs from the git repo code and they match the client exactly. I didn't check every class and level range, but the ones I did check look good. AllaKabor also gives the same numbers. So I guess it's just the magelo bugs that we've noted before.
