GINA and Gamparse on OSX
Discussion in 'General Discussion' started by Dane, Dec 14, 2016.
  1. Dane
    Dane People Like Me
    I know some people are anti-GINA -- that is not what this thread is for. I want GINA for an invis dropping trigger when I'm 3 boxing and crawling through a dungeon and a timer overlay trigger for respawns when I'm pulling cycles.
    Is there any way to run GINA and/or Gamparse on OSX?
    I use Gamparse by creating an app through WineBottler. Haven't been able to get GINA to work.
  3. kicnlag
    kicnlag Active Member
    In typical weekend project fashion I started creating a poor man's GINA for macOS but havn't had the time to sit down and get it to a point where its worth sharing.
    I've figured out a lot of the "major" pieces (Text that overlays the game. Text-to-speech. Tailing the log file.) but havn't actually created "triggers". I wanted to research the formats GINA/GamTextTrigger use but havn't gotten that far.
    Here's a screenshot of the overlay showing the last line from the log file:
    Maybe this thread will give me a little more motivation.
  4. necra
    necra People Like Me
    Bump- anyone found anything like this for OS X
  5. Lenas
  6. Bum
    I don't support this cheats
  7. Lenas
    Thats surprising because you support every other cheat until GM's patch them
    Mambo and Diro like this.
  8. Bum
    I don't use 3rd party software, which this is
  9. Bum
  10. Lenas
    ftfy
  11. Dane
    Dane People Like Me
    All it is is a log parser. Also, pwease halp. I need mah GINA.
    Quirk likes this.
  12. Darchon
    The ability to use GINA on PC Client makes up for that client being far inferior to the Mac client.
  13. Pane
    Pane Member
    If you wanted to open source this I'm sure there's plenty of people who would help. I don't know objective C but I'd love to look into it
  14. Dane
    Dane People Like Me
    Bump. Halp.
  15. necra
    Bump
  16. sowislifesowislove
    Damnit. Saw this appear in new posts. Went from 6 to midnight to 6 :(
  17. necra
    as an update on getting real gina to work through wine, i managed to get .net 4.5 framework installed on wine but seems windows installer 4.5 isnt working on wine and that is holding me up from actually installing it. it prob wont work but figured id post just incase somebody knew of a work around.
    Quirk likes this.
  18. Slayzz
    Did you ever get any further Into developing a Mac supported version?? Thanks!! #ginaenvy
  19. Morbo
    Morbo Well-Known Member
    Does GamTextTriggers not work on Mac? It's super simple and does everything OP wants.
  20. Lenas
    No. Any Gam features other than basic parsing are unreliable at best and crash the app at worst on a Mac. Gamparse also can't even read logs from the first 9 days of any month without editing in a leading zero ahead of the single digit.
  21. Dominar
    Dominar Well-Known Member
    Bump. What version of GamParse will ready OSX client files? I downloaded the current 2.0 beta and I can open the gui with wine+mono but it reports an error for every line in the file when I try to open a log file.
  22. Mokli
    That newer beta might not work at all with the Mac or PC client here. v1.6.1.7 is what I use on PC. I can send it to you on discord if you need it.
  23. Mokli
    I did some snooping. You can find the older versions under the lastversions or oldversions folders here: http://elitegamerslounge.com/home/gamparse/
    If you install one of the 1.5.x.x versions it should update after a few runs to 1.6.1.7
  24. Mokli
  25. Dominar
    I downloaded 1.5.2 and it reads the logs fine. Although I didn’t see a self update, just a link to the forum where only 2.0.0 is available.
  26. Lenas
    Gamparse has an issue with how the mac client prints log lines from the first nine days of the month. It looks for a preceding zero, but our client doesn't print one. Example:
    [Tue Jun 1 13:25:36 2021] <-- Mac client
    [Tue Jun 01 13:25:36 2021] <-- Gamparse expectation
    If you find it crashing when trying to run certain log files, this would likely be why. At least in my experience. A quick find/replace throughout the file will make it usable.
  27. Walex
    Alternatively, limit your play sessions the 10th-31st of each month
    Ransom, Lenas, Ripwind and 1 other person like this.
  28. sowislifesowislove
    ha ha. Just sit there and make jokes from your GINA high tower.
